3D AB RENAULTE ABS SYSTEM CODE
15 years 9 months before #9387 by manual-mecanica
3D CODE AB RENAULT MEGAN SYSTEM PUBLISHED BY MANUAL-MECANICA
Hello friends, I have a problem in a Renault Megane, the hand brake witness, Stop, ABS, Serv. I have scanned the vehicle and I get the 3D code the same that says "Solenoid Valve Circuit of Admission Right Tracera" "active.
I want someone to tell me what is that valve, where is Uvicada and that I must do?
15 years 9 months before #9501 by manual-mecanica
Manual-Mecanica Response on the Re: 3D Code ABSault Megane System
Good
It would have to know what type of ABS carries your car, but ultimately the fault is in the ABS set, there are van the four valves, one of each wheel and the press recovery pump among others. According to the diagnostic machine you have you can do some check as accused the valves manually or see the work tension, and if they are activated or not.
Good luck and you will count.
