Do not turn on my 90 g1 1.8 goal
15 years 9 months before #9455 by manual-mecanica
Do not turn on my 90 G1 1.8 goal published by Manual-Mecanica
Hello friends, I hope you can help me I tell you what happened to me ...
Look that I get in the goal for the U Then I rebuild the girdle that goes from the alternator to the water pump then it stacked me and I return to the parking lot as like about 700 meters which when I arrive at the parking Then I left the battery and I noticed that a thick positive cable is running with the can. Well and today that I wanted to scratch, turn on the fan but when I give it the Star (the ignition) with the key does nothing, it does not turn on although the rest I light the audio and the pilots. Then I empoxe and Aramco left it a good moment like this then it goes out and I wanted to turn on again and nothing will be an idea and help me please
15 years 9 months before #9457 by manual-mecanica
Manual-Mecanica Response on the Re: Do not turn on my 90 G1 1.8 goal
Tell me when you place it in Star produces some noise, if it does it can be the clear boot engine depending on the noise; but proves by starting directly to the starter engine.
Now this are mere assumptions according to what you say what happened to you but nothing you lose with trying. I hope it helps you in something ......... GreetingsXD .
15 years 9 months before #9461 by manual-mecanica
The positive cable you mention you installed again or left it like this, that cable is thick is from the starter engine, of course if you are touching the ground, I recommend you check the fuses first you want one, I do not think it is complicated nor of the other world checks and warns,
15 years 9 months before #9465 by manual-mecanica
Hello friends, thank you very much that I would like to explain how to try the aranque engine directly
15 years 9 months before #9469 by manual-mecanica
To try a starter engine directly, you have to send direct current to the thicker screw of the starter engine, that is, the battery positive to that screw, after you can make a bridges between the thinner cable of the start that is like a male leg, or as you carry yours they are being one of the other, and the vendix would come out, so that you turn you have to make the cables as they are also You do this with a screwdriver and turn to turn, the earth is made by the body of the start.
