Measure the temperature of my goal 90 1.8
15 years 9 months before #9519 by manual-mecanica
Measure the temperature of my goal 90 1.8 Published by Manual-Mecanica
HELLO!!
Friends I would like to help me, I will instruct me I have a VW goal 90 1.8 and the temperature meter is harvested and I would like to put one I already have the tacometer to measure the temperature and I would like to know how to populate it, I try but the needle when I turn it up, I go to the other end I hope you help me friends I will thank you for some.
15 years 9 months before #9524 by manual-mecanica
Manual-Mecanica response on the Re: Measure the temperature of my goal 90 1.8
Hello, look at the temperature meters watches comes the positive 1 volume sensor and a dough (fix if you put the safe mass that is not connected)
greetings that depends the mark of the same: Laugh:
15 years 9 months before #9543 by manual-mecanica
The truth is that it depends on the brand and if it is electric or mechanical as the two models are called, but in whether the installation is simple, but if your goal is electronic you will put an electronic meter, since the other model gives that fault, a positive and a negative is simple, what differentiates the sensor itself is the sensor itself
15 years 9 months before #9546 by manual-mecanica
Hello friend thanks for the comment and help but I would like to help me more deeply how the temperature meter is connected : blush: : blush:
15 years 9 months before #9557 by manual-mecanica
Tellos that meter you have, if you can supply a better photo, now a query when one buys a clock almost always breaks with the plane to install it, but if it does not bring it, well, it would help some photos to know it as much as many cables it brings and that.
