Temperature marker in my fiat siena
15 years 9 months before #9578 by manual-mecanica
Temperature marker in my fiat siena published by Manual-Mecanica
Hello, how are you, I have a problem with the needle that marks the temperature in my Fiat Siena 98, when the car is running at times it stays at zero; To return to mark the temperature I have to turn off the car and turn it on. I think I don't mark the temp. Corresponding, I don't know if it is a problem of vulvo or electric, I would appreciate any suggestion.
15 years 8 months before #9587 by manual-mecanica
Manual-Mecanica Answer on the Re: Temperature Marker in My Fiat Siena
Generally, such problems are electric and lie in bad lands, the bulb is to pass the radio and run the electros, the clock marker is another, it has a single cable and it is not expensive, change it and button up because testing them is a bit complicated.
15 years 8 months before #9588 by manual-mecanica
Thank you very much for the help.
