Renault 19 Diesel Correa
15 years 8 months before #9643 by manual-mecanica
RENAULT 19 Diesel Correa published by Manual-Mecanica
Hello everyone:
my old man has a 19 diesel renault and the "poli b" belt is not frequently cut off, it is called, it is the one commanded by the water pump, the direction, the alternator, etc.
The issue is that I take it to several mechanics but do not find the solution, could anyone help me with the subject?
Thank you very much
Guillermo
15 years 8 months before #9652 by manual-mecanica
Manual-Mecanica Response on the Re: Renault 19 Diesel Correa
Hello,
I would check the tensioner of that belt, check the bearing of it and even the bearing and alternator pulley.
Don't you make you noise?
Greetings.
15 years 6 months before #10761 by manual-mecanica
Hello, I am Luis the problem is solved, but you have to fix the alignment of the alternator the pulley is too desalination, it spends it on your side and it takes it out to you.
