Hello ... when you start it ... and if you don't accelerate it ... it is turned on? .... only when you accelerate it goes out ... If you may be dirty in carburetor .... You run out of gasoline? What you can do quickly and see is the following ... take out the spark plug and place it in the four and four in the one .... GIVE LEAVING AND YOU WILL MAKE YOU AN EXPLATIONS IS TO TAKE YOU
Uuu what turnip ... I didn't see that you solved it ... well luck
