Ok here in Chile they are told Takis, well, these hydraulic takis that are the ones that you have effectively sound when they are downloaded or when they are in poor condition, what I recommend is that you check the olgure that it exists between the taki and the upper part that acts or retains it, you have the same with the avajo part, suffer wear and stay with olgures, if you have chauz. To be sure, if what you want is to silence the noise to be sure, you can swell the oil with an additive, if the problem is the takis, the noise is kita if it is by olgura decrease but do not disappear, it is nothing serious in any case, do not despair.
