Abs Toyota Hilux 2007 Model
15 years 8 months before #9751 by manual-mecanica
Abs Toyota Hilux Model 2007 Published by Manual-Mecanica
Hello, forum partners, a Toyota Hilux 2007 arrived at the workshop with the light of ABS on; Someone will have the diagram to facilitate the ABS of this vehicle; I tell you that you have new pills, and tapes well accept some comments that you can give me to solve this problem.
Thanks in advance and greeting to the entire forum
15 years 8 months before #9756 by manual-mecanica
Manual-Mecanica Response on the Re: ABS Toyota Hilux Model 2007
Friend the ABS of the toyotas can only be turned off and check with a scanner, now what you can check is whether the electronic commands of the pills are connected if it is that in your case it carries, but in some models it turns on this light when the pills are spent as well as the balatas, it is not many what you can do without a Scaner be to be that there is no other problem so as not to disarm more, abesses with a cleansing enough since the roads get dirty.
15 years 8 months before #9795 by manual-mecanica
Thank you for responding, in the end we connect a scanner and shoot six failures and could direct the search to the rear circuit of sensors and find two cut cables of them at the height of the medium of the differential that we repair and I am walking.
I greet the entire forum
