Marintense I always recommend two things for cases such as yours, first to make a basic refinement, this is a change of spark plugs, air and fuel filter, to rule out that it is just a bad combustion problem, but for what you say and the data that you deliver the problem you have is the clutch disc and the smell you felt like it was not oil but the disc burning. When this component begins to fail, it is formed when you ask for strength and in plane or less pronounced slopes it is not appreciated, but if you do not change it, it will be committed to feeling already to give problem, you feel that when you put the fifth march and accelerate it, it does how it accelerates but does not get it?
