high flow filter
14 years 9 months before #16031 by manual-mecanica
High flow filter published by Manual-Mecanica
Hi, I would like to know how the high flow filter helps me or prides me in a Seat Leon 1.8 without turbo.
14 years 9 months before #16158 by manual-mecanica
Manual-Mecanica response on the Re: high flow filter
The filter helps you and that more air enters and more freely to the engine what gives it more potensia and a more racing sound that harms it is that the car will be consuming a little more combudible
14 years 9 months before #16161 by manual-mecanica
It could be true what they say about the high flow filter, but it must also be considered that these filters do not prevent the particle entry that can produce wear in the cylinders, pistons and rings or rings of the engine, the increase in power is not large is practically imperceptible, and it is logical that consumption increases, if more air volume enters the engine should increase the dosing of fuel.
13 years 7 months before #27585 by manual-mecanica
Forget about high flow tunning filters, most of these components are authentic garbage that are useless except to empty your pocket in trouble with the car, or do you think that Volkswagen does not know how to make their air filters?
13 years 7 months before - 13 years 7 months before #27609 by manual-mecanica
Thus he is a friend, the high -earth filter .. or flow ... or whatever you want to do not serve anything more than two things:
1 ° to let dust particles inside the cylinders and consequently they act as a sandpaper and create premature wear to your engine and
2 ° for nothing more than the same thing that at point 1 .. hehe
do not spend friendly on those things, the design of the original air filters
Greetings
Last edition: 13 years 7 months before by .
