I have a problem with an astra
15 years 9 months before #9530 by manual-mecanica
I have a problem with an astra published by Manual-Mecanica
I just acquired a 2006 engine of 2.0 Ly engine was stopped a lot of time for a year and a half and the drum
15 years 9 months before #9549 by manual-mecanica
Manual-Mecanica Answer on the Rera problem: I have a problem with an astra
Good, it is possible that you have a problem with the diesel, an air intake, or the very old diesel B) B)
15 years 9 months before #9550 by manual-mecanica
Forgive that it is of gasoline truth ,,, thus throw new gasoline and see if lellega current to the spark plugs ,, sorry for the before I thought that Diesel was Diesel : Woohoo: : Woohoo:
15 years 8 months before #9560 by manual-mecanica
Hello, I recommend that you also check the injectors if it is mpfi, they can be obstructed with the gasoline wax, if so clean them to pressure, (this happened to me with a tsuru III also with 1 year stopped .... luck and comment results ... do not forget to assess answers ...
