SYMPTOM: The vehicle loses power, walks as with obstructed escape, and you have to revolutionize it a lot to grab speed.
Problem: tightening of the central bolt of the incorrect Damper.
Solution: Tighten the Damper with the corresponding torque.
This is a design problem, the crankshaft key is harder than the crankshaft and that the Damper, the wear produces a game in the Damper that the superior dead ditch reader carries, by this rush the point is delayed, the point is advanced, a solution re -apprehens with a bolt trave.
Hojo: In extreme cases it is so much this wear that it is revealed to rectify the tip of the crankshaft and the draft of the pulley chavetero, and create a less hard key.
