Rover 75 / Rover 620
13 years 1 week before #35252 by manual-mecanica
Rover 75 / Rover 620 Published by Manual-Mecanica
If someone had the Rover workshop manuals or tell me where I can download them, I would appreciate it since when the cars are not manufactured it is more difficult to repair them and find spare parts. Thank you
12 years 9 months before #37209 by manual-mecanica
Manual-Mecanica Answer on Rover 75 / Rover 620
Hello, apologize, what engine the rover? I have the 2.0 TD if it helps you send me an e-mail cesar.mechanic@hotmail.com . Nafteros 1.8, 2.0, 2.3 are Honda engines in 600 the 2.0 Turbo Naftero is Rover, in 75 2.0 and 2.5 are V6 and the diesel is BMW.
12 years 9 months before #37250 by manual-mecanica
Thank you for answering, I have two rover the 75 is a 1800 gasoline, and the 620 that is the oldest is an SDI, 2000 engine, if you had any manual I will thank you for my e mail is sobarzocarrillo@yahoo.es greetings.
12 years 9 months before #37686 by manual-mecanica
Hello Chilespa, there I sent you the manuals of the rover to your e-mail, tell me if they arrived and if you need the user manual, or of gearboxes and I send them, a hug. :) :) :) :)
12 years 8 months before #38187 by manual-mecanica
Hello, I would like to know if someone has the engine manuals of a 75 V6 2.5 rover of the year 2000, I have in the workshop one that passed through bad hands and becomes a nightmare of faults, sounds, heating etc, as several have put hand, I can not trust how it came armed, some of the problems: rattle sounds, rpm unstable, heating and finally. Water, disassemble the engine, and before the desengle check comprehension and system leaks, the 3 cyls of the front with the comprehension of 120 psi more or less couple the 3 behind 70 and 65. When checking the distribution bands, (I do not have the synchronization data) checking the overlap for me, it is evil synchronized the rear head. When the engine wisdoms, I noticed that the refrigerant passed through the base of the shirts and that the cylinders 1 and 3 are with the piston arrows pointing to the steering wheel and the others Asia the distribution! Can someone help me? Asia where the pistons should point and what are the zincronisation brands, thanks and I hope you help me. carloscar_72@hotmail.com
