I do not see so simple "parts exchange" that you carry from 2.2 to a 2.0, you have to know if you changed the gasoline pump or it is worth what you had, if it maintains the same pressure and flow for injection; Then this that the butt supposes that it will be different in terms of valves and camshaft and the theme of ignition ... has no strength because the same is missing or left over of gasoline ... Quitalo the spark plugs to see if they leave white, or soaked with gasoline, look to see. Greetings!!
