Good friends I tell you I have problems with Toyota 2KD does not come to the injectors already try the EDU in another truck and work well try the ECU and it also works well also probe also a crankshaft sensor, cams sensor, rail pressure sensor and all work in the other truck and try the lines and all are fine, they are well cut, the pump and injectors were a laboratory All the fuses and everyone is fine
