BMW 316 m40 problem
10 years 8 months before #47521 by manual-mecanica
BMW 316 M40 problem posted by Manual-Mecanica
The temperature rises very fast to the mita but it does not happen I have cleaned the radiator that is ostrured but it is still the thermostat well and temperature
blas
10 years 8 months before #47523 by manual-mecanica
Manual-Mecanica Response on the problem with BMW 316 M40
Urgent help you get the temperature very fast to half but it does not go from there is already cleaning the radiator Purge well and change the thermostat and the radiator temperature ampoule and it remains the same
10 years 8 months before #47524 by manual-mecanica
Good afternoon you have to check the water or engine re -circulation pump
10 years 8 months before #47525 by manual-mecanica
Thank you for a good answer, I tell you
10 years 8 months before #47528 by manual-mecanica
I suppose it goes up until the thermostat opens if you want to know if that is the problem annuls the thermostat provisionally then puts and tesacaras the doubt
