Mercedes Benz OM 352 Motor Manual
15 years 3 months before #12259 by manual-mecanica
Manual-Mecanica Response On the topic Re: Re: Mercedes Benz OM 352 Motor Manual
Hi Angel, I am missing the power-cat-torque-conasumo curves with the variation of the RPM, of the OM 352A type engine, which was mounted on the Mercedes Benz 1518 trucks, the same is 5657 cm2 and 185 hp of power.
They came in the user's manuals and in some advertising brochures.
I bought an OM 352A engine and I will ride it with a pump to remove water, I have to adapt in the motor to the pump through a pumping head (similar to a differential), it comes with different gear relationships; The bomb manufacturer will tell me how many HP will absorb me to move it, and I will have to do with these curves that I look for what I have the HP that I demand that they demand me, in this way I will also have a minimum consumption of fuel since I will not get more HP out of those who are going to need.
To the tables I am looking for them in concessionaires, in workshops and in the 0800 of Mercedes Benz and I was not lucky.
I am going to attach some photo and file of some similar tables but of a cummins, so you can see how they are.
I thank you for everything you can help me.
Greetings.
Fabián
[IMG/]
[file/]
15 years 3 months before #12261 by manual-mecanica
Hi Angel, I can't load the photos or the file, I don't know what I'm doing wrong, I'm going to continue trying.
Greetings
Fabián
15 years 2 months before #12326 by manual-mecanica
Look if it serves you is OM 352 but does not differ in much. LUCK ANGEL
15 years 2 months before #12327 by manual-mecanica
Look if the attached file serves you
15 years 2 months before #12362 by manual-mecanica
Hi Angel, Siiiiii !! I think it is those that I need. There is a possibility of increasing the resolution since I do not identify the values ​​in the curves. In the tables I see that the OM352 and the OM352A are too. With this I believe that I am going to have the information that I need, it would be good to see if you could upload the file, or the image with more resolution, since I cannot see the values. I thank you very much for the hand you gave me. Greetings.
Fabian
