Problem with 4WD Isuzu D-Max 3.0
15 years 6 months before #10911 by manual-mecanica
Manual-Mecanica Answer on the Re: Problem with 4WD Isuzu D-Max 3.0
Mr.
Oswaldo Romero,
like the others, I require the graph to be able to reset the double transmission module. How do you send it to me and how much is it worth?
15 years 6 months before #10912 by manual-mecanica
All estimated, here you can see the graphics, do not depend on a character that does not share knowledge www.twistedandes.com/for/showthread.php?t=56406
12 years 8 months before - 12 years 8 months before #37630 by manual-mecanica
Manual-Mecanica Response on the problem with 4WD Isuzu D-Max 3.0
I had problems with the DMAX battery and when I changed the check 4WD and does not work the double traction I can do to solve the problem? The model is 2008 and the connectors are not under the passenger seat
Latest edition: 12 years 8 months before by .
12 years 8 months before #37639 by manual-mecanica
Hello brother, I hope you dedicate a little time to help more friends of this forum ._ above the brake pedal
12 years 8 months before #37640 by manual-mecanica
I will try, thanks for your answer I hope to get, apologize that I abuse myself, do you have manual of that pickup?
