Problem with 4WD Isuzu D-Max 3.0
12 years 8 months before #37641 by manual-mecanica
Manual-Mecanica Response on the problem with 4WD Isuzu D-Max 3.0
One more thing once you place the cables you must open the switch, the double check will appear, you will listen
12 years 8 months before #37649 by manual-mecanica
Thanks to your help I could reset the fault, very grateful for your support.
12 years 8 months before #37808 by manual-mecanica
Manual-Mecanica Answer on the Re: Problem with 4WD Isuzu D-Max 3.0
I need the graph please colleagues
10 years 2 months before #48894 by manual-mecanica
If it is common in the DMAX the damage when known actions are performed in the DMAX I send you such a file the check code
8 years 3 months before #52102 by manual-mecanica
Friend the solution is easy to clean the connectors and then connect them in their place goes to the interior of the car and place the key now press the three 4x4 buttons for 15 seconds without releasing them Turn the key to the switch position until they turn on the lights of the board and continue clicking for another 15 seconds the buttons and I hope it helps you serve you
