Oxygen sensor failure
15 years 5 months before #11295 by manual-mecanica
Manual-Mecanica response on the re: oxygen sensor failure
Hello thanks for the various answers and check the sensor wiring since it effectively has two sensors, and all the wiring is seen in good condition, they mention a program to scan the sensors or the car computer online could give me the link to lower it, and where I can look for them current values ​​that tell me about the sensors a thousand thanks to all and happy 2010.
Atte. Tino:-)
15 years 5 months before #11297 by manual-mecanica
Hello: A sensilla and economical form of testing the oxygen sensor is with a multimeter, you place it to measure continuous current voltage and in millivolts, you place the multimeter to mass cable (-) and the positive to the sensor signal cable that in most sensors is black or blue (the sensors B Black, 2 White and
Grizo
15 years 5 months before #11313 by manual-mecanica
Hello, regarding program paid for scanning are copies with Internet crack, Digimoto, PCMScan Data Pro, Scanxl, Diagnose 41, Scantool22, Obd2ceazy
etc. They require an electronic interface to connect to the car. The cheapest and easy to locate are the ELM327 version 1.3 or 1.5 or its Chinese clones that bring basic software.
On the Internet are the planes of the elM interface module of several models but in the main chip it is not commercial, it is only sold by a factory, it is an integrated Pal * Logic Array program with the anticopia protected program.
The interface is worth about 39 dollars in China. in transport as 35 more and delay 5 days by DHL and arrives at the door of your house. This artifact reads fault codes, motor parameters, not all and reset the checine light with its original program.
With other programs he does more things.
To see the cheap interface and scanner, look at this page www.ipmart.com
Search Cars and then Diagnostic Tools in the upper horizontal bar.
They are distributors in Malaysia and China of everything and sell per unit if you want
luck
