Ford Explorer EsportTrac 2005
15 years 4 months before #11543 by manual-mecanica
Manual-Mecanica Answer on the Re: Ford Explorer Esporttrac 2005
I forgot that trick I will rehearse thanks for your answer
15 years 4 months before #11544 by manual-mecanica
Hello, just a question The position of the camshafts are left butt with the trigger of the sensor above and the right butt in balancing?
15 years 4 months before #11553 by manual-mecanica
Greetings friend and calm that we will somehow reach the problem. Now because of the last comments and seeing some manuals I am with the doubt that the engine is the one that your truck has I thought it was a 4.0 now I am sure that we are talking about the same engine, please could you clarify ...
15 years 4 months before #11564 by manual-mecanica
Hello if it's 4.0
15 years 4 months before #11565 by manual-mecanica
Greetings friend, I tell you that here we are at a medical board between 4 mechanics including my potato that is already retired. We think that the problem should be in the cylinder cylinders (rings, pistons and shirts) and that you should make everything measure. Now we think that when you disarm you should detail whether the admission multiple is fine, it could be that it has a loss by a packaging or that it could be torsid ...
