92 Seat Marbella Change Box
15 years 4 months before #11640 by manual-mecanica
Fass in Seat Marbella Change Box of 92 published by Manual-Mecanica
Hi, I'm new in the forum, I need help by changing the valvulina of the change of my Seat Marbella of 92. It takes a screw with head tor, and Aharus does not enter the march behind.
It has repair or you have to disassemble the entire gearbox
15 years 1 month before #13738 by manual-mecanica
Manual-Mecanica Response on the Re: Faulture in Seat Marbella Change Box of 92
Hello, I am also new in the forum, and I changed the clutch to a Marbella Iwal, and kitated that screw and I put on the thing iwal, you have found a solution? eske I am iwal if you know anything comment and if I know I tell you a greeting
15 years 1 month before #13744 by manual-mecanica
Moment where this Torx screw that they talk about is located, if it is that of the gear selector lever, it is only a matter of regulating it and it is no longer complicated but say where the screw is to help them.
15 years 1 month before #13770 by manual-mecanica
The Torx screw is located next to the 17 KE screw is the Kita to replace the valvulina, the Torx screw is 8 mm x 40mml can be done well without needing to disassemble the box? all the best,
