Isuzu 1.8 Diesel does not start
15 years 2 months before #13131 by manual-mecanica
Isuzu 1.8 Diesel does not start published by Manual-Mecanica
Hello everyone, someone can help me, I have an isuzu 1.8 diesel and it does not start already heating injectors corroborates the point, fuel etc but does not want to start what you notice is that it aspires little for the multiple of admission when I start it but I had never really set me how much I aspired when I was right then I do not know if it is evil or not if someone has an idea of ​​any other way.
15 years 1 month before #13218 by manual-mecanica
Manual-Mecanica response on the Re: Isuzu 1.8 diesel does not start
Have you already looked at the Pare Electrovalvula? And have you taken it?
15 years 1 month before #13220 by manual-mecanica
I do not take it out but I feel when putting contact that works and also pulls some smoke when starting but I will take it out to corroborate the same if you have any other idea I grab you thanks for your contribution greetings
15 years 1 month before #13289 by manual-mecanica
These engines tend to step on the valves, check the adjustment
15 years 1 month before #13518 by manual-mecanica
Good afternoon, try to review the compression of this engine this will identify you if it is low if it is so throw a drop of oil through the injectors and re -measure the compression you can verify if so if the problem comes from cylinders or valves, if this was correct, try to throw a self -arrange for admission (little) sell it in spray this must give you a result that at least the engine manual and that of the Opel Monterrey that carries this same or identical motor encourage and luck
