Hello friends, I found this paguina where people will help mechanical problems. good. Well I would like to tell you that I have a Volkswagen Polo Classic 2002. My first car and fucking that cost me to have my car. Well, the problem is that when I stopped the vehicle at night or for more than 8 hours it is hard for you to leave or not. But I have a bridge or put the charger for 30 minutes part of the altiro. Well if someone gives me some advice or some data I appreciate very good good luck with your cars good vibes ..
Thank you very much colleagues. Lescuento that if when I disconnect the positive terminal and I want to place it sparks. and the vehicle is off is leviously on the patent light. But I get everything about the ampoule light and the ampoule holder. But and Gual leaves. I would like to. If someone knows the good and discharge electric gun. Because I am already arto with the cable. Well Puenteo when I stop it for more than 1 day or if it exhausts it in Lamañana. thanks for everything.
Hello friend, do a simple test, at night when you leave the car in the garage and no longer loues until the next day, disconnect the negative terminal of the battery, the next day connect and start it, if it starts without problems it is not of the battery and you will have to look for where it is downloaded, something that is lit consuming or some short in the wiring etc., tell us that you discover, luck and greetings.
The most caused thing is that your battery does not need the load and does not keep it, you change it and it is already, but you have the test that Jal tells you and there is another simpler disconnect the terminal and with the whole car off, and the door closed to avoid the burning inner light, leaves the glass below if we perhaps, and connect it if they jump sparks there is a ghost consumption, but I think it is only a battery, luck.
