I have a small or serious problem
15 years 1 month before #13314 by manual-mecanica
I have a small or serious problem posted by manual-mecanica
Ok my problem is that my Hyundai Accent of 95 broke a piston: Ohmy: and is not a race car: Silly: . Make a engine with the mechanic that is fixing it. The problem is that the engine is not from my car as I know because it is missing to endure the support of the back of the engine. It turns out that my car is from the year 1995 and according to search is 97. I have been told that it can be from Brio that that is why it does not bring where to put that support. The problem is that a piece can be put to be able to endure the engine on that support ????? Don't be welded or something?: UNSURE:
15 years 1 month before #13322 by manual-mecanica
Manual-Mecanica response on the Re: I have a small or serious problem
I have electromechanical studies of vehicles. It sounds fatal to me about welding a support. You have an identical engine even if you have to ask for it at a distance. It has to be somewhere !!
15 years 1 month before #13323 by manual-mecanica
Ja here in Argentina or sticks we buy an engine only fix them less headache at the time of paperwork and adaping.
So expensive do you fix it to put another engine?
15 years 1 month before #13340 by manual-mecanica
Here we also repaired it, but I should understand you evil. Show the peston and voila.
15 years 1 month before #13343 by manual-mecanica
Well what happens is that the piston broke the block lid and the block and because the mechanic told me that it was more expensive to fix it than to buy another new one. The new engine didn't get so expensive. But then I think it will bring me problem if it is true that the piece can not be welded to endure the support I lost the money ... what happens if it is about welding something to the engine ??? I mean taking the piece of my other engine and put it to the new ????
