My golf 86
15 years 1 month before #13474 by manual-mecanica
My golf 86 published by Manual-Mecanica
Hello, I hope to have your problem with my golf mod. 86 is the following when heating tironea goes out and does not start already changed the distributor, they told me to change the water pump (I need to change) what problem could the thermostat be serious? I hope your help thanks Abraham
15 years 1 month before #13479 by manual-mecanica
Manual-Mecanica Answer on the Re: My Golf 86
I do not think it is the thermostat but if you have doubts, just take it out and the vehicle without thermostat and out of doubt, I think it can go for the teaching module.
15 years 1 month before #13480 by manual-mecanica
With all due respect I do not see any relationship with the water pump, verify whether the papalote from the top of the carburetor that closes when the engine is cold opens when the engine is already heating, this papalote moves with a thermostat that the carburetor has on one side, I hope I help you my comment.
15 years 1 month before #13494 by manual-mecanica
Thanks for the comments, already check the papalote and that's fine, they could be spark plugs changed them but I put used.
The other is that my golf is platinum, but Porke fails me when the TMB car is heated. I put the new coil. Spark plug cables, and I don't know anything else. thank you
