Mazda 626 1991 starter engine
15 years 1 month before - 15 years 1 month before #13483 by manual-mecanica
Mazda 626 1991 departure engine published by Manual-Mecanica
Hello, well, I make a query ... I am in charge of a family car ... and that he had made him losing the water pump ... but my brother after that ... handled it and gave him = that and the engine presylted .... From Ahy no more ... when he gave contact it was heard that I turned some Check ... well and if not, how can I get the starting engine to check it ... I would appreciate advice ... I'm studying mechanics and I want to learn by doing it ... Thank you very much ... I hope answers ... chao
Latest edition: 15 years 1 month before by .
15 years 1 month before #13505 by manual-mecanica
Manual-Mecanica Response on the Re: Mazda 626 1991 starting engine
The starting motorcycle is easy to get only a bit uncomfortable, in the MASDA the battery, negative, disconnects the starter motor cables and removes the two 12mm bolts that carries and leaves back and only tests it as a turn and sies that rotates.
15 years 1 month before #13513 by manual-mecanica
Today a teacher ... He told me that the engine has been decomposed ... that it is the same as it is known that it was melt ... I wish no ... ok for your contribution ... I will do it
