My car does not start
15 years 1 month before #13526 by manual-mecanica
My car does not start published by Manual-Mecanica
My car is a Hyundai Elantra year 94 engine 1.6 Double camshaft. A while ago, it was over the road and stopped, all mechanical work adjustments, rings, pistons etc. were carried out. I have a spark and fuel and still does not start if someone could help me agadeed ..
15 years 1 month before #13532 by manual-mecanica
Manual-Mecanica response on the Re: my car does not start
If you have a spark and fuel, then the distribution may be badly left or there is no compression in the cylinders.
15 years 1 month before #13533 by manual-mecanica
You would have to check the intoxication pedal or the sensor, these cars do not turn on if they are not stepped on the pedal that is on that side greetings
15 years 1 month before #13641 by manual-mecanica
The distribution is correctly, the Endague pedal sensor is good the engine rotates and the compression of the cylinders is No. 1 90, N ° 2 90, No. 3 70 and No. 4 120 yet turns and gives the impression that a small impulse will be missing to start greetings ......
15 years 1 month before #13642 by manual-mecanica
That compression that mentions in cylinders 1 2 3 are too low, they would have to be in 120 so that an efficient comprehensive comprehecion is made if the engine was adjusted then the Czech repair fails again and check the compression, if everything is rectified can escape by valuables, it is not a good comorecion
