I turn on check often
15 years 1 month before #13623 by manual-mecanica
ME LEADS ME
I have a D-MMAS 3.0 TDI already on the route the light of Check Engine and low of revolutions, the engine is normalized and after a while someone knows what the truck can be new is new has 76,000
15 years 1 month before #13628 by manual-mecanica
Manual-Mecanica Answer on the Re: I turn on check Engine often
The best way is with a diagnostic machine, but the bosilation of revolutions in Relay is generally because of the IAC, in Ford it works both high and low, but leave the doubt with a diagnosis.
15 years 1 month before #13637 by manual-mecanica
mmm you have an intermittent flashing The first thing you have to do is to delete the fault codes if you appear another code looking for the failure code circuit is not always a sensor or an actuator :)
15 years 1 month before #13639 by manual-mecanica
thank you so much
