Fairy in Toledo
15 years 1 month before #13735 by manual-mecanica
FAIR IN TOLEDO PUBLISHED BY MANUAL-MECANICA
Hi, I have a toledo1.8 Monopunto injection that consumes too much and does not remain at the idle.
Give an error code 2122.
Help.: S
15 years 1 month before #13736 by manual-mecanica
Manual-Mecanica Response on the Re: Averia in Toledo
Hello, the same problem but in Renaul, I solved it by changing the idle valve, in case it helps you
15 years 1 month before #13743 by manual-mecanica
You talk about two different problems The IAC valve is generally the problem of Relay, and consumption excess is usually the fault of the oxygen sensor, check both to be safe.
