Diesel low pressure problems in Accent Crdi
10 years 3 months before #48749 by manual-mecanica
Manual-Mecanica Answer on the subject Diesel's low pressure problems in Accent Crdi
I have an Accent Prime Diesel 2005, something similar happened to me .. in reaity it happens to me ... and I asked in a workshop and wanted to extort myself ... I know some mechanics and it was not necessary The tip carries a microfilter .. take out that piece and torch with precion or mandela air to clean with ultrasound where they repair pumps ... with that the problem will be solved ..
10 years 2 months before #48925 by manual-mecanica
Manual-Mecanica Response on the Re: Dismressing Down Pressure Problems in Accent
Hello, for me, they are the injectors has a way and that leaves the Common Rail system unction you must repair or replace the injectors
