Hi Kaprissss, whitish spark plugs in the electrode indicate a poor mixture in gasoline, do not give importance, squeeze them well and now. Through the butt joint, purge the circuit well with the started engine, the cap removed and sees prepared for when the electrventillator jumps Add more water if it requires it at this time, put the plug and leave it torn until the electro is saved again (sometimes it takes a long time) when it stops this, turns off the engine and let it cool at all, if necessary, fill up to the level. If you appear out of there, you consume water and do not run away anywhere, it wants to say that it "is burning" by an internal leak in the butt joint. You have only to see that white smoke comes out in the escape if the leak is important. Changing the joint to this engine does not bring greater complications. He squeezes the exhaust collector, who still fuck you gases by the collector's board (the nuts are usually loosen). It is not worth "bursting" an engine for such a thing, if you change your together, this is not worth more than 50 euros in any store, and so you will know how to do one more thing. Download the manual that will do well. Greetings and encourage !!!
(Forget about the level of the hot glass, just see if it lacks water when it is already cold, after having walked with it)
