Eclipse 98 brake pills
11 years 1 month before #46217 by manual-mecanica
Eclipse 98 brake pads published by Manual-Mecanica
Good morning, I have a mitsubishi eclipse 98 and I would like to put competitive brake pads, the problem is that the seller of them needs to know which the measure of pills that the car brings original (high, wide and thickness) and I cannot find this data anywhere. I suppose this data must be in the manual or you must be able to find out by chassis, but I do not find anywhere the eclipse manual for the 97/98/99 models. If anyone knows this data or has that manual, it would be of great help. Greetings and thanks.
11 years 1 month before #46366 by manual-mecanica
Manual-Mecanica response on the topic Eclipse 98 brake pills
The best thing you can do as practical and easy is to get a pill and take it there is not much work in that, in the manual the dimenions of the pills will not come out. If you do not approach a house of brakes and that you check for the catalog, but beware of the occasion, it changes within the same year the shape of the pill for that it is best to take it out and take it.
11 years 4 weeks before #46390 by manual-mecanica
As the fellow Kikemec says, take them out, but what I do is put them on top of a paper and copy the shape (both the pill from outside and the opposite of the same brake) and then remembered them, so I go by car with the copy made on paper to for the new ones. Greetings!!
