FIAT SCUDO INTERMITENCE Relay
11 years 1 month before #46223 by manual-mecanica
FIAT SCUDO INTERMITENCE RELAY PUBLISHED BY MANUAL-MECANICA
Hello!!!! I just bought a Fiat Scudo 2.0 JTD from 2005. For a few days, the flashing or warning has not worked for me. From time to time they work for a while and then stop working.
They have told me that perhaps it is the relay, but although I have located the box of the relays, in the user manual it does not appear which is the one corresponding to the intermittent. Does anyone know ??? Any van workshop manual around ???? All the best!!!!!!!
11 years 1 month before #46256 by manual-mecanica
Manual-Mecanica Response on the subject Fiat Scud
Hello, it is not reliable, what you are looking for is flasher of intermittent and is located in the fuse box if you do not know how you have to do the intermittent OH the hazard and the box that sounds is and if you do not work only give it a blow and you will start flashing in general because of the work it has the welding is off but it is better to change it luck I hope I hope to have helped in something ...
11 years 1 month before #46257 by manual-mecanica
He wrote: Hi is not reliable what you are looking for is flasher of intermittent and is located in the fuse box if you do not know how it is to do the intermittent OH the hazard and the box that sounds is and if it does not work only give it a blow and will begin to flash in general because of the work it has the welding takes off but it is better to change it luck I hope to have helped in something ...
Excuse me if it is a Fiat may that the flasher valla in the command of lights and for that you must take the cover that covers it : p
11 years 1 month before #46274 by manual-mecanica
Look if it turns on at some point follows the noise it generates, because I have encountered fiat that the flash is the same cat button and spend hours looking for this happy unfortunate Jajajaj, if it still sounds follow, it is relatively easy to identify it if it is normal flash has three legs unlike the relays that possess 4 or 5
