Honda Civic 95 Turbo Problem
11 years 1 month before #46246 by manual-mecanica
Honda Civic 95 Turbo Problem published by Manual-Mecanica
Good I have a Honda Civic 95 Turbo and the problem I have is that he does not want to accelerate after the 3000 revolutions, Chipie the computer and does not want to accelerate, who believe it can be the problem is pleased.
11 years 1 month before #46270 by manual-mecanica
Manual-Mecanica Answer on the Honda Civic 95 Turbo Problem
The first thing is to return to normality and see how it behaves, on occasions they do not look good or the chip does not correspond and pass these problems, the cutting limiters or the range does not correspond to your model, if not that, you could have clutch problems, but this gives you some clues Coo for example the revolution Chipeo were not little possible that it happens, the bad thing is that in mechanics there are never impossible is always the possibility that very rare things happen. Well proof and let us know, luck and not hopeless that everything has a solution
