Help Palier Seat Ibiza 1.4 8V 1995
11 years 1 month before #46295 by manual-mecanica
Help Palier Seat Ibiza 1.4 8V 1995 Published by Manual-Mecanica
Good commented on my problem if anyone knows this system, I was looking for the workshop manual of my car but I only find 1997 and the type of engine is different.
It turns out that to change the clutch, the box goes down, and the right shield (the length) did not go out for more than loosen the six Torx screws that the homocinetica carries, it turns out that this stick is not flat the homocinetic like those of a lifet box)
So the problem is as follows:
- To put the whole whole of the homocineta and the balls, take out what was attached to the box thinking it was flat like this,
And it turns out that it is:
and wears keys like you are doing a ring,
My question are the following:
If someone had the workshop manual of my model I would answer it myself ... Type of ABD engine and year 95
- To mount the stick I have to put the last piza taught first in the box because it goes with a screw, so if it mount the whole set of balls and homocinectic it would be in them because I cannot put the screw that fixes the unique piza of the photo, then I will have to mount the piece release first, which is where the balls go and then how do I put the stick? Because the balls do not enter the balls of almost 90º as a minimum to make the balls and with the mounted box there is no space,
In short, I would appreciate a lot of help and if it is the manual much better because here it costs a lot to express
Thank you very much for the attention, great the page great information and here we will be for what you can contribute. greetings
11 years 1 month before #46297 by manual-mecanica
Manual-Mecanica Answer on the subject Help Palier Seat Ibiza 1.4 8V 1995
Maybe everything mounted in one piece, schered I did not understand you well, but I would ride everything outside, I would cost the screws and to the pressure (like the staple that the Opel carries). What I do not understand where you say that the piece takes the screw; If it goes inside and then you have to mount the other part (the balls), that you have to look for turning the posture (just like it came out, it must enter), I know that sometimes it is not easy to do ... patience and to see how it occurs.
11 years 1 month before #46311 by manual-mecanica
Hello. Maybe these drawings help you, I do not know if they are from the Ibiza model you need, but in any case it will be something similar. greetings
11 years 1 month before #46318 by manual-mecanica
If what is disarmed was the part that does not enter the box, no problem is the potato weapons everything outside and then you go inside, now if what is disarmed is the striatum that enters the box Cuec that if it is more complicated not to put the striatum that is easy, just make sure that the satellite of the box is not broken, although I doubt it.
