Turbo pressure hose is strangled.
10 years 11 months before #46755 by manual-mecanica
Turbo pressure hose is strangled. Posted by manual-mecanica
I have a Mazda BT-50 Turbo Diesel 2008. And when I accelerate I get strangled or suck Turbo pressure hose at the entrance of admission multiple. I would appreciate some help.
10 years 11 months before #46765 by manual-mecanica
Manual-Mecanica response on the subject is strangled Turbo pressure hose.
Hi Osvaldo, check that the intercooler is not filled with oil, when the admission aspires from this hose, if the intercooler is plugged, you would be pulling white smoke, another thing may be that the hose is not its own (which has put another softer /eg, and already very strange it would be that the air filter was totally saturated. Greetings!!
10 years 11 months before #46793 by manual-mecanica
Hi Osvaldo.
The thing is rare because the turbo sends air with greater pressure than the engine aspires naturally, as Ismael tells you, check intercooler and turbo the same as air filter, you can try without the filter to see if it improves.
LUCK
MIGUEL
