Twingo who stops
16 years 9 months before #4490 by manual-mecanica
Manual-mecanica response on the re: twingo theme that stands
The name of a piece is turning sensor or engine of the engine, and to change it only a necsitas a ten alfredtenerife@hotmail.com
16 years 9 months before #4492 by manual-mecanica
Good area to install, especially in the aspect of work, as a mechanic it will not be missing. Not as in the islands, that you have a quite bad year according to the reports that come to me and with the workshops that I speak of there.
16 years 9 months before #4493 by manual-mecanica
ok thanks I warn you if I have problems that I buy it tomorrow,
greetings
16 years 9 months before #4525 by manual-mecanica
Well, apologize that I do not have an answer to your problem but you know more than me from the Twingo I have one that the digital tacometer stop working what the speed marks if you can tell me what it can be because it is crazy to me as well as the air compressor goes out alone, I started at the time I frame the fault of the tacometer I imagine that it is of that same problem thanks beforehand beforehand
16 years 8 months before #4721 by manual-mecanica
Good friends I think I also have that problem with my car, it is a 16v twingo year 2006 he turns to touch but sometimes he does not turn on, I thought it was a gasoline problem and it was not, I thought it was distributing and 7 either, the strange thing is that when that happens that I try to turn on empomedy and the turns, it will be the same problem with the idle sensor ???
