Tense belt of a kangoo
15 years 11 months before #8778 by manual-mecanica
TENSAR BELT OF A KANGOO PUBLISHED BY MANUAL-MECANICA
Hello people, someone knows how many mm of tension carries the distribution strap of a kangoo, in the manual they show how they measure it with a speech that talks about sem units that have no convert to mm. I ask how many mm because here in Argentina you get a device that is something of 270 pesos but measures the tension in mm.
If anyone knows anything, I would appreciate the data.
15 years 11 months before #8781 by manual-mecanica
Manual-Mecanica Answer on the Re: tense belt of a kangoo
Hello friend if you do not have the device tensala so that when you take it between the thumb and the index in its longest section you can barely twist 9 90 degrees there you look perfect, luck and greetings.
15 years 11 months before #8783 by manual-mecanica
Hello the tension of the belt either of the alternator or the distribution, or any strap when you do not have the tools and do them by hand, you have to tighten in such a way that you can move it or twist it a little less than the ninety degrees, I take as an example the belt of a pants, when twisting it remains with its inner face looking out.
15 years 11 months before #8784 by manual-mecanica
Hello friends, thank you for presenting, I am going to pay attention to you, the alternator's belt never found the right tension, more than anything because of the topic of preserving the rulemans, the apparatus to tighten it I am doing by copying it from the original, I barely finished it I put the pictures and I say how to do it, it is very simple. What I am going to do is finish it, tighten the strap based on what you advised me not to exceed 90 degrees and there I will take measure with the apparatus to see how many mm they are.
The apparatus is that of the photo but it is in mm, if twisting the 90 degree strap it looks good is not worth spending so much.
being that it is so easy to do.
15 years 11 months before #8785 by manual-mecanica
I take advantage of the march to ask them, as they do to lock the distribution, they do it if or if with the accessories that come to lock everything or there is some homemade way of locking the injection pump, the crankshaft is locked with a nail type that I suppose it should be about 4mm thick, the gear of the tree of elevas according to the manual is put up in the mark and calculate that nothing should be moved. The subject seems to me that it is in the injection pump.
Does the belt bring the 3 brands? Cams, pump, crankshaft?
The theme of the tension of the belt; A screw is placed on the side (in the block of the block, according to manual), which pushes on the tensioner's track, is it like that?.
a hug
