Tense belt of a kangoo
15 years 11 months before #8786 by manual-mecanica
Manual-Mecanica Answer on the Re: tense belt of a kangoo
Thanks for the fact, the less at 90 degrees I have to tighten it? To twist it I need to do it with both hands? or with a enough one? a hug
15 years 11 months before #8791 by manual-mecanica
Hi Juan takes the strap between the index and thumb fingers and there and there tries to twist it must be a little less than 90 degrees you will already realize alone and you will not have problems, a hug.
15 years 11 months before #8797 by manual-mecanica
Thanks for the fact, I am going to do as you tell me and then I will test it with the device that I already finished it, if they are interested, I put a photo and tell you as I did, it is easy a piece of iron angle and piece of rod rod a pair of nuts. But as a base I will take what they tell me about bending the belt.
My big doubt now to start changing the distribution strap is how to lock the gear of the injection pump? do I do it to work it?
A hug for all and thanks
15 years 11 months before #8801 by manual-mecanica
With one hand with the thumb and index, about 70 or 75 degrees will be enough,
15 years 11 months before #8802 by manual-mecanica
Friend look how advice I tell you that when you change the distribution strap you make brands, mark with a liquid corrector, I don't know how they are called in your country, well the idea is as follow teeth and this, a question for you to need to bring the pump pulley to remove the pulley, or only to hear the distribution.
