Charade tends to stop the engine.
15 years 10 months before #9035 by manual-mecanica
Charade tends to stop the engine. Posted by manual-mecanica
Hello, I would like to consult you the following problem I am having with my HC Motor Charade.
When I turn on the lights or start the electrventillator the engine tends to stop, I understand (with my basic knowledge) that there is a sensor that should command a diaphragm but I am not finding it.
If anyone knows their shape or where they would be housed and the operation would be very grateful to me.
Thanks from now.
Oscar.
15 years 10 months before #9039 by manual-mecanica
Manual-Mecanica response on the Re: Charade tends to stop the engine.
That problem you have is for the alternator, you have to check it, so that you are sure to start the vehicle and with this walk it disconnects the battery if the engine stops the problem is an alternator, that if you do not have a tester, it is not highly recommended to do it, if you have a test tester check how much load
15 years 10 months before #9041 by manual-mecanica
Thanks for your help, I will review it.
Do you mean trying the load tension?
Apparently I have no battery charge problems, I never stayed without battery.
Then comment on the results.
15 years 10 months before #9042 by manual-mecanica
Manual-Mecanica response on the topic temperature sensor
I would like to please help me, my problem is the following I have a ZX2 escort, and I bring a very strange noise, near the engine, already check it and find that the support or good where the temperature sensor is mounted is broken, (this is right next to the engine) I would like to know what this part is called, to get it I know what is what causes me the fault because once I had already damaged me, but I do not give it to me, but I have not damaged me, but I have not given it to me, but I have not given it to me,
I hope you can help me ....
15 years 10 months before #9054 by manual-mecanica
Manual-Mecanica Response on the Re: Temperature sensor
Ask for it alone as well as temperature sensor support, but when you break you lose liquid those surely bad.
