Take the car to repair because the Injector 3 Board (the joint between injector and butt) fogue. They changed it and when I took the car, I started pulling (when you feel like it), until one day I left lying on the highway (pulling sack, tremors, endured the slowdown just and noise that something had been released in the engine, apparently a dripping injector). He took it and told me that I had grabbed the injectors 1 and 2. They took them to the firefighter and unbridled them. They gave me the car and the 4 km again problems of tremors and that does not endure the idle.
Back to the workshop, they put the diagnostic machine, and no electronic failure, but measuring how injectors work it is seen that 2.3, and 4 work the same but the 1 works stronger. In the workshop go blind diagnosis and me too. They will take the 4 injectors to the firefighter again but I do not know ...
someone who has had an equal or similar situation, helps.
And another thing, which has to do with the copper joints of an injector and end up failing the injectors?
