Prolble of the 4WD D-Max Diesel 3.0 unit
15 years 8 months before #9613 by manual-mecanica
Prolble of the 4WD D-Max Diesel 3.0 Unit published by Manual-Mecanica
the light of the 4x4 witness became
15 years 8 months before #9618 by manual-mecanica
Manual-Mecanica Response on the Re: Prolble of Unit 4WD D-Max Diesel 3.0
It can be the bulb that is through the box, if you say it turns on without connecting the 4x4 can be that bulb with a defect
15 years 8 months before #9635 by manual-mecanica
You want the light informing you of a failure in your box, perform a scanner and be ahead before it is too late, the repair of boxes are expensive.
15 years 8 months before #9752 by manual-mecanica
I work in GM and I can get you the pins that have to be built to turn off the light but it has to have a failure.
15 years 7 months before #10152 by manual-mecanica
:) Hello, I am Juanra and I want to know what are the pins that I had to bridge to turn off the 4WD Failure Light of D-Max 3.0
I have several manuals and if I can help something just let me know
