That truck has some sensors similar to the retro light switches to indicate the situation in which it is to the transfer control ... I imagine that your problem is that the witness is being lit even when the transfer switch is disconnected.
The first thing you have to do is make sure that the transfer is not connected ... Upload the 4 wheels in the air and have with the engine on that they turn forward in 1st and the transfer selector in 4h or 4L and make sure that the 4 wheels turn if it does not do so means that the transfer clutch is not working or in its defect the control solenoid but if it does so there is no problem. Now connect the transfer switch in 2h and check that when putting change and making the vehicle go, they are only working the rear wheels, if they still do the front it may be that the selection switch is damaged or also that some of the position sensors of the pinions or the transfer clut Based hate just changing it
