Hi DiegoFP80, look at the Santamo manual in particular I don't have it, but I have some manuals from other hyundai that can serve you, I can pass them through mail tell me your email and send it to you. I also had problems with starting once, suddenly he died and the problem was that the gasoline pump had been locked, I realized why the current consumption was excitely for the chocolate, the medium and consumed me 13amper when they consume 2 amper is a lot. I solve it by taking out the tank pump and connect the feed to the setback to turn it in the opposite direction and thus it is deleted, I will save me from spending $ 950 that is what the original new pump comes out. Regarding the tuning this vehicle is complicated because according to the manual I have, it says that to put it on time, the scanner must be connected and disconnected a way so that the ECU does not correct the point every time you turn the sensor that captures the position of the camshaft. I had many problems with this car not because the car is bad but because they had put a bad hand but now it is working quite well. where are you from? Eye talked about the tuning with non -distribution belt lamp.
